POLO 6N - strange main beam warning light
Between the fuel and temp gauge there's a single round area where the main beam blue/white light comes on when beams are on.
Driving yesterday just had normal headlights on and at high speed i noticed the main beam indicator come on for about 3 seconds but it was yellow!?
I thought I was seeing things as sun was setting and though it was that. But then it happened again ten mintes later.
Yellow wtf?
On that morning all I did was remove battery cover and remove a plate covering to allow you to see rubber bushing on top of the gear box mount.
  • Replies 8
  • Views 1.2k
  • There is a blue filter for the main beam light so it couldn't be that unless it has burnt through??
  • as above, try pulling the indicator stalk and see if the light is actually blue. There is nothing in the battery area that would relate to this light other then the bulb holder itself or the headlig
  • Check the 19 pin big round connector by the radiator top hose
There is nothing in the battery area that would relate to this light other then the bulb holder itself or the headlight connector but that would make it light up blue.
Thanks lads. I will check this.
both main beam and headlight are not working on passenger side. must be something connected.
Yep. Must have hit it when taking out the battery, it was out abit/loose. lights working again now lol
So when driving must have fallen out or caused a surge to make the blue main beam dash light flash yellow (that bit I still don't understand.)
Edited by damunk
I imagine the dipped beam feed must have bridged with one of the main beam pins, thus both making one light (or both) flash the main beam and also powered the little light.
Yep . . i think we can bring this investigation to an end.
