6n2 gti headlight washers not working?
Hi I have a 6n2 gti and the headlight washers are not working anyone no if it is a easy fix our hard?
  • Views 2.3k
  • Ok first thing check fuse # 47 in main fuse box , it supplies the power to the contact of the headlight washer relay in the front of the engine bay, if the fuse is OK then run a thin wire from the bat
Can you hear the pump running? do the units lift out of the bumper cover freely ??
No mate can't hear anything and they don't come out at all but they are free I lifted them out and put them back in
Ok first thing check fuse # 47 in main fuse box , it supplies the power to the contact of the headlight washer relay in the front of the engine bay, if the fuse is OK then run a thin wire from the battery POS to the pump connector ( White/Black wire) if the pump doesn't run it's the pump or the ground for the pump, if it does run then the relay is at fault or you have a wiring defect to the relay
Thanks mate I'll give that a go tomorrow then I'll keep you informed
Got it sorted mate. Was the fuse just thankfully. Thanks for your help :)
