G40 / GT Throttle Cable Wanted
I'm after a G40 / GT throttle cable with the small metal clip that holds the cable once adjusted on the bracket bolted to the inlet manifold.
In good nick!
Thanks, Gary
07429 990 091 give me a shout if any of you do
  • Views 281
Any mk2f throttle cable will work as long as it is from a right hand drive car and has the part number
868 721 555 A
Hopefully that will widen your search...
Thanks, think I may have sourced one, if not I'll update in here.
Is it a new item you have found? If so, let me know where. I'm after a new one.
Cheers,
Scott.
I have one off a mk3 I broke if you still need one. Drop me a pm
Edited by Gaz
Cheers,
Scott.
VW Heritage can order them from Germany, for around £30 delivered, three week wait on it though....
I managed to get one second hand, it turned out to be longer than the old one already on it. The metal part near the pedal was longer! Managed to make bracket to compensate for the difference in size but its not ideal. Do the Coupe S use a shorter cable compared to the GT / G40 then?
