Hello All!
I have for sale a Megasquirt 1 ECU
EFI EXTRA MS1 ECU Fuel and Spark Control
4 Injector outputs
2 Spark outputs for a wasted spark ignition setup
Can be used with VR or Hall sensor for trigger
All other information on this ECU can be found at http://www.extraefi.co.uk/
£200 Posted
  • Views 735
Pm'd
Grab a cracking bargain here folks!
Is this just the ecu or all associated wiring aswell?
This is just for the ECU you will require a new Megasquirt blank loom which can be purchased very cheaply or you can by the parts and make it yourself, I would do the latter as you can accomodate for different wire lengths.
The loom would have to be redone for your engine setup regardless.
Still for sale?
I have someone interested but not yet purchased
