1.4 16v 100bhp (6n2) 5 door model whats she worth
Just wondering what my 1.4 valver 100 bhp model would be worth now, i know the 100bhp ones are quite rare so I'm told, its 100% original.
Its has the decent 8 spoked 15" alloys that came on it, a bit scuffed here and there but would look sweet with a small refurb
its a W reg 2000 model and covered just under 120K, uses a bit of oil, water levels are fine etc has past its MOT every year since I've owned it since (2008)
abs sensors done last year
bad bits:
Drivers window switch faulty so swopped it round so passengers 1 does drivers (new switch will fix)
drivers door lock dont work ( have to lock it from passengers side) not an isssue though can be replaced cheaply
passengers seal has been welded as previous owner must have damaged it and got it cheaply repaired ( has taken 7 yrs to show through so I've not fixed that)
engine management light is on have cleaned the throttle body out i think it needs a new oxygen sensor ( this is work in progress)
drivers wing mirror was smashed off so a replacement is a different colour as my colour is hard to find
post-9278-0-69797200-1439869958_thumb.jp pic for ref only not my car
Simon
  • Views 583
£1.50 and a bottle of Irn Bru?
It is hard to value a car over the internet. Some more information regarding MOT and service history would be handy. Also as the mileage is pretty high, any info on if and when the timing belt and clutch etc. have been done.
Those 5 bad points you mention, although they are nothing major, you and anyone coming to see the car know they are all pretty cheap and easy fixes. But they give leverage to haggle. Get them fixed, I'd say engine light would be your first priority as trying to sell a car with an engine light on could mean the difference of a few hundred quid.
Assuming the service history is decent and up to date, there is plenty of MOT and you get those issues sorted then I'd say it is an easy £800-900 motor. But as always it is a case of it is worth what someone will pay for it.
Has this got the afh engine? Where are you based?
i believe its the abu if i remember correctly, id need to double check in the boot to be 100% sure. based in northants
Most likely to be an AUB engine :)
Sorry yes it is the AUB, typo on the last message, I've scanned it and it needs a new lamda sensor which is an easy fix, with that its a really good runner still got lots of poke for its age!!!
