Abs light
I've just done a engine conversion on my 6n ( put a 6n2 gti in ) and changed all the looms now I have come to a problem.. I haven't changed the brakes over yet as they have bigger brakes on anyway but they haven't got ABS where the loom has the ABS in so when I turn the key the abs light is on but I don't have abs.. How can I go about turning this light off? Thanks :)
  • Views 470
I'm guessing you have a later 6N with the fuel & water temp gauges in the top centre?? if so you just need to Ground on pin 19 of the Green connector on the speedo or pin 10 of the Green 10 pin connector at the rear of the fusebox or pin 16 of the ABS control unit plug
