brake servo to inlet manifold pipe
Has the one way valve on with the two connections for the vacuum pipes. Ideally only need the valve but will take the whole thing if necessary.
  • Views 298
Which model is this for ?
Do you have a pic of the valve needed ?
one of those... but with an unsnapped vacuum line connector at the top.
I managed to get a replacement from a 6n mate. Just to widen your search
Theres 3 variations of the valve.... i need the one with the 2 vacuum pipe connections which many models dont seek to have.
Have one now thanks to Peteg40 :)
