lowering Q
If I drop my mk2f about 70mm on coilovers will I need shorter tca's or will the standard ones work? Also what else do people recommend changing whilst lowering on coil overs?
Cheers in advance
  • Views 618
Just change the too mounts. Might have to replace tca's if the ball joint is worn
Do you mean top mounts? And ok cheers
arb blocks and poly bushes in the lower arms would be worth doing too
