ABD engine! 1.4, painted, 1.4 mani and cylinder heads. Sold! Please remove
having a bit of a clear out from my lockup as I need the space!
I've had the motor for a while now was planning on putting in it my old polo but found a 1.6 and stuck that in instead.
the motors stripped ready to put your dizzy/alt pulley and whatever manifold setup you going to run on.
painted the block, oil pan, pulley and the rocker cover in satin black.
Cleaned the head.
I've changed the belt, pressure tested the head and changed the oil filter.
the cams a stock 030 AH (GT) with no scoring or marks.
these don't pop up that often so thought ill sell it as its not doing a lot sat in the lockup!
the golf I took it out of was on 120,000 when I removed it.
£230 I need it gone! for the engine I can stick on a pallet if you sort a courier out, but would much prefer cash!
£40 for the clutch kit (brand new luk never used) SOLD
£65 for the 1.4 inlet setup (mani, carb and top hat)
£35 1.0 cylinder head
let me know what you want and ill get a price for postage (apart from the engine)
message me on here if your interested in anything unless you want a quick reply text me on 07545778958
Cheers'en!
post-917923-0-66894900-1441236187_thumb.
post-917923-0-11140000-1441304133_thumb.
post-917923-0-42951800-1441304155_thumb.
post-917923-0-32098400-1441304175_thumb.
post-917923-0-95383000-1441304204_thumb.
Edited by Sidney93
  • Views 565
This is not a tall block engine
Got a part number of the LUK clutch?
Taking it this is gone now? commented a while ago on your facebook with no reply
Engine still available or not?
