6N2 Rear Stub Axles, Hubs
Wanted, 6N2 rear stub axles, hubs, disc backing plates from rear disc brake models such as the GTI. Must be in useable condition.
Wanted, a pair of rear stub axles from a rear disc braked model, 6N2. Many thanks.
Closer to Northampton the better, otherwise you may need to post.
Edited by Bluemotech
  • Views 402
still needed.
Updated, still need a pair of stub axles. What have you got?
Stub axles should be the same for drum or disc, the bearing/hub unit that fits onto the stub axle is certainly the same item
The drum stub axles don't have the mounting points for the caliper carriers. I checked that one out with parts diagrams.
