6N polo slammed
Right guys I've had a 6n for a right while now and I want to get it sitting on the ground using coilovers is this possible cause I know another guy that has one and he can't get it any lower and it still sits kinda high, can anyone shed some light on this ?
  • Views 833
You will need to take off the helpers if you not done that already
The first set of coilovers I had I didn't take them out I've a brand new set here and I'm gonna take them out of it, will it leave it much lower tho ?
You will get an extra 10mm or so with the helpers out. However I'm sure if you have a front anti roll bar then once you get down to a certain ride height this stops you going any lower.
Ah that's ok then there is no anti roll bar in my car anyways so this works out even better
