Vw polo coupe cl 1.3 - for sale £650!
Vw polo coupe Cl 1.3
I brought the car as a project around 6 months since then I have some bits to the car including.
All plastics sprayed black
New wipers
New bulbs all round
Clear indicators
Front pads and disc
Rear wheel bearings
Rear shocks
Front shocks
Spark plugs
Ht leads
Distributor cap
New lamber sensor
New battery
Oil filter
Oil change
Fuel filter
New coolant bottle
Pressed plates
Lowered 70mm on springs all round
Has an mot until July 2016
I have not driven the car much only around 400 miles as i have another car.
Bad points are -
The car stalls when coming to a stop now and again (has always started again after)
The body work is okay for a 24 year old car but there is light rust on both front arches and some small dents around the car.
There is a knocking coming from for the gear linkage when the car idles I believe it's just a lose linkage.
There is a small hole is the rocker cover which I had temporally patched over.
The polo had only done 57400 miles
I have loads of old history including services and all receipts for items listed above.
I'm around £800 in on the car but realise it will not see for that.
So I'm after £650
  • Views 406
Car is located it Colchester Essex
Don't know how to add photos on so will try to sort that out tonight.
