Engine parts and gearboxes including gripper, Corbeau polo seat runners
ATV box with gripper diff £650
GT box SOLD
G40 brakes, green stuff pads, drilled grooved and vented discs, braided pipes, new sliders SOLD
Head with double springs no cam( skimmed and valves lapped in) £80
GT block, crank, pistons chemically cleaned and honed with new bearings rings and shells (mahle) ready to rebuild SOLD
GT bottom end already built with new water pump £100
Lightened GT flywheel SOLD
Vernier pulley £70
4 gasket sets
Corbeau polo seat runners SOLD
G40 ko3 turbo manifold cracked but repaired professionally £100
I also have loads of spare mirrors, Alternators, starters etc.....
Edited by kanokid
  • Replies 19
  • Views 832
Depending on where you are I'll take the gt box
Still have a lot of spares, including rebuild kits,
I am also breaking my polo in 2 weeks;
Red power coated to a high standard
ATS Classic 6J with matching tyres - £300
Front strut brace - £35
5 speed Anti roll bar - £40
Rear beam with gladerseite bushes and rear brake drums with new hoses - £150
Engine/gearbox mount - £15 each
Alloy cam cover - £100
(MH 1.3 rebuilt 1500miles ago( red sump with magnetic plug, red water pipe, red alloy cam cover, 272 Newman cam, head rebuilt, double springs) - £350 Have a print out for 90bhp)
H&H ignition dizzy( recommended by bogg brother no need for vac/adv, Carb wiring harness and ignition module, Flamethrower coil (with red bracket) - £165
Magnecor ht leads and custom king lead - £60
Brake stone guard - mint condition - £25
Brembo brake disc - £20
Brake caliber with fresh pads and new hoses 1000 miles ago - £15
5 speed re-conditioned gear shifter with new bushes - £40
5 speed drive shafts - £30
Gladerseite ARB blocks - £30
Bottom arms with gladerseite bushes - £40
Front steel strut brace - £30
Rear alloy strut brace - £20
Ashley 4 branch - £90
Powerflow straight through to back box - £200
OMP steering wheel with boss - £100
Diblias weber twin 40 - £80
Scuttle tray - £20
Tim water temp gauge and sender unit
Tim electric oil sender gauge with sender unit
Tim amp gauge and sender unit
Tim Rev counter
£40 each, £120 for all with cage for radio slot
What are the part numbers on the Corbeau frames?
Is the scuttle tray just a standard one?
Is there a gt fuel rail for sale?
That a price for both stone guards/dust shields?
yes.
If that's a posted price I'll take them
Still these parts available:
Vernier pulley £70
4 gasket sets
What about those brake shields?
Let me know if you decide to split box from diff. I'd be interested in the box :)
Box won't be split I'm afraid
What's in the gasket sets?
All gaskets for the head
Pm'd you
Does it say what engine codes it covers?
Wer bouts are you buddy
croydon
FY engine code
You got ecu for gt
