Cbr600 bike carbs mk2 ignition setup
Have had a change of plan and have decided to sell my bike carbs and ignition setup
Carbs have been cleaned and mounted to a manifold for a afh I've not had them running or setup
Ignition is a mk2 dizzy 030905205a which has had the advance locked i also have the vacume module loom and ignition amp i haven't got a coil
The manifold is a bit rough but am sure it will work
Not sure how much it is all worth so gonna say
£225 inc postage to uk mainland
Located in suffolk
Edited by wally79
  • Views 393
Can you give any more detail about te locked advance? Quite interested.
As far as I'm aware there is a screw in the outer body that has been replaced with a longer one that then locks the disc inside
