Boot light - mk2/f
Hi all,
Did the mk2/f ever come with a boot light?
Would there be a way to fit one in an oem way? Ie no drilling holes etc
  • Views 819
As far as I know only the loons had em, the coupes and breadys didn't :|
I have found out however that a light in the centre of the plastic cover on the boot door is positioned perfectly to illuminate the boot... one option would be to get ahold of a second dome light, cut a hole in the plastic for it and wire it up. Wouldn't actually be OEM, but would look it to anyone who didn't know anything about Polos :tongue:
Edited by Vio
not seen one as standard , if you dont want to drill look at the ebay led strips , they're self adhesive flexible strips that you could hide under the catch area or speaker shelf and they're very bright
http://www.ebay.co.uk/itm/121661534826?_trksid=p2057872.m2749.l2649&var=420664792356&ssPageName=STRK%3AMEBIDX%3AIT
i put a pair of those in our other car as footwell lights and I'm really pleased with em
Sorry, I meant drilling for a switch. How could we go about using a switch on the latch
I had a look and there isn't a place for a light unit under the shelf brackets so I guess I will need to get creative :) I have got a box of interior lights from a local breakers so will see which fits best.
The switch side of things I think will be a little trickier
I just bought a magnetic one from Wilkinsons and stuck it to the back of the seat. Works perfectly. Just switch off and on with button. Best simple upgrade I've done.
I think I'm going to have to give up on fitting a light as the latch mechanism is going to need a bracket made and a switch and it's just too much right now so I think I'm going to go the magnetic light route.
£4.99 and it lights the entire boot up when needed.
Thanks for the idea buddy, solves the darkness problem :)
