Safety First - seat belts
Evening all, I have yet another boring question to put to the masses. I'd like to replace all my seatbelts for new ones but this one http://www.gsfcarparts.com/890vg0030 from gsf is not correct despite putting my reg no. into the site. It wasn't until I tried to fit it that I realised the mk2 has three small bits of bodywork bent inward towards the back seat bench in a sort of this shape \ _ / which fits into the holes on the seatbelt reel to ensure it's mounted perfectly straight.
I have found a number of them for sale on ebay but I idealy want to fit brand new ones. I've searched VW heritage and had no luck so far.
If anyone can point me in the right direction I'd be very grateful.
  • Views 810
If you have the Catalogue Number then you can try searching for it in BKS-Tuning.
all of their parts are brand new even for older cars, I got myself a new door grab handle for my 6n2
write the number here and I'll try to help you
Edited by mishawel
I'll try to find out a cat no.
thanks
But take it to your attention you might not find it since your car is 30 years old
Edited by mishawel
Front
867857705C three-point seat belt with inertia reel / belt lengthened by: / F ..-E-000 001>> left 300MM /
867857706C three-point seat belt with inertia reel / belt lengthened by: / F ..-E-000 001>> right 300MM /
867857705B three-point seat belt with inertia reel left /
867857706B three-point seat belt with inertia reel right /
Rear
867857805A three-point seat belt / relay fitting / F ..-E-000 001>> ..-E-200 000 rear chrome colored / POLO, POLO COUPE
867857805B three-point seat belt / F ..-F-000 001>> rear / POLO, hatchback; POLO COUPE
867857805C three-point seat belt / belt lengthened by: / F ..-E-000 001>> rear 300MM / POLO, hatchback; POLO COUPE
873857805B three-point seat belt / F ..-F-000 001>> rear / DERBY, POLO CLASSIC notchback
873857805C three-point seat belt / belt lengthened by: / F ..-E-000 001>> rear 300MM / DERBY, POLO CLASSIC notchback
theres places you can send them away to and they refurbish them , can even get differant colour belts
Front
Rear
Nice work nige. That's one part of the problem solved, now I need to find somewhere that actually stocks those codes.
I have taken a look at the part number on my seat belt this evening and it is indeed 867857706B for the drivers side so I would say that the numbers posted above by Nige are spot on. If anyone knows where I can find a set of these new I would be chuffed to bits.
867857705B
867857706B
I'm yet to check what the back ones are but I assume it's 867857805B
