6n2 heater bulb
How do I replace the heater bulb in 6n2?
I understood there is some centre knob I need to pull out, what knob? the 1-2-3-4 levels of the air flow?
If so, how do I pull it off? maybe the same as pulling the light switch out? {pressing and twisting?}
Edited by mishawel
  • Views 620
The central knob (Fan Speed) it just pulls off, then you can remove the bulb, you might need some rubber tubing to pull the bulb out
so just pull the knob out? no twisting or something?
NO just pull it off !!!
sorry :tear:
Thanks for the help
