Rear Passenger Door 9n won't unlock
The passenger side rear door of my 9n won't open, even if pulled from the inside. Any ideas how I might open it? it's almost as if the catch won't disengage when the handle is pulled. This started off as the door not unlocking and I could open it with the interior handle. Now I can not do either. I can't see an easy way to do this as the bolts that hold the door cards on are on the underside of the panel, hidden by the sill.
  • Views 1.9k
Your going to have to sacrifice the door card to get at the latch mechanism :(
I thought that might be the only way. they're hard as fuck though. I've had to sacrifice one before!
