Would these fit on a 6n 16v front bumper?
Hello peps. I'm looking to buy some fog lights for my polo 6n which will have a 16v bumper on soon.
Will these fit?
post-920579-0-61685600-1443617902_thumb.
Item no 250774154216
Or are they for the 6n2?
Thanks Nimal
  • Views 684
By the years shown in the picture, then they should fit the 6N1 16v bumper
Thanks . Was trying to compare them to the 6n2 ones. But these look like it will fit the 6n . I'll order them tomorrow night payday. Thanks again
They will fit, but the lights are terrible and rust up inside within a few weeks. The output is really crap too.
If you changed the lights for something oem from a breakers yard they would be way better, but chances are they are a special size.
Ahhhh crap. I already ordered them . Thanks for the feed back dixy. If worse comes to worse ill just use the housing and try source some fog lights for them. Like the look of these compared to the oe 16v fog lights.
Depending on size you could you the generic type of fog light most cars use now. I got some the other day off a Renault Megane and they are exactly the same ones I've got from many other cars like VW t5 Range Rover l322 and later BMW they are flat lenses and simple mounting holes. Imitation need to make a bracket to hold the lights as having them on the grille is asking for them to fall out :)
Hopefully yours are better then the set I got a while back
