Polo GT block & heads
Polo GT Engine
• Block
• Head
• Bare skimmed head
• NO CAM
taken when i got it
original head, cracked and sheered stud on dizzy side
haven't a pic of the skimmed head yet, I wrapped it up a while back to store it
never used it, beenunder the work bench in the garage wrapped in plastic
£150 collected in crawley
Edited by kiran_182
  • Views 462
  • yeah sorry, crawley. i had an old phone thatuse to autocorrect it to brawley which is more accurate block was on around 100k looks fine, just been sitting for a while I do also have inlet, injectors
When you said crawey did you mean crawley? Also what are the miles on the block and is it in good nick?
I was originally after an ABD but I may change plans to a Gt as I can get all the injection parts from someone who has it all
sorry mate also, what would you want for just the good head and block and what would you want for the block alone? does the cylinder head have double valve springs?
I do also have inlet, injectors, throttlebody induction elbow and arm
the skimmed head is bare, so no parts atall with it. the other head is complete, I also have a 3rd damaged head from a gt that could be used for parts
Edited by kiran_182
Fair enough sounds alright then really, what sort of price do you want the other stuff sold for? I'm a bit skint so i would have to wait if i took the engine first anyway.
Would you do a little bit less on the block and heads being that the valves will have to be lapped into the good head etc?
SOLD
