Need Urgent Help !
Just fitted brand new angel headlights to my 6n(99). But have now discovered that the full/high beam does not come on as this happened to the standard headlights and angel lights after them. Making these 3rd set of lights on car.
Does anybody know what this problem could be as iv checked all wiring on back of headlights etc...as its only the drivers side NOT working ???
REALLY NEED HELP ON THIS.!!!!
  • Views 524
Popular Days
Does the full beam light in the speedo work? as that is from the drivers main beam, if that doesn't work check fuse #12 (10amp) if that's OK check there is 12v getting to the headlight (White wire), if there is no power there, check the main headlight disconnect plug, it's a big round connector by the radiator near the battery
