Parts I've salvaged of my Polo :( 99 6n APQ LC6M
ALL IMAGES CAN BE FOUND HERE - http://imgur.com/a/1frx4
I will update as and where I can so as not to disappoint
All prices are collected, postage can be arranged at cost!
Pagid Discs and Pads, covered about 6k miles, plenty of life left £25
Polo 6n Pedal Box, no cracks, plastic clip on rear of brake pedal is broken so will need yours £25
Throttle Body from APQ engine, fully working £15
Cam shaft from APQ engine, includes gear £20
Indicator Stalk, fully working £5
Steering Wheel Slipring with Airbag wire £5 - prov. sold
APQ rocker cover with nearly new gasket will fit most 8v engines £10
6n Airbag Module with passenger bag deactivated, it does say non-transferrable, no idea how true that is, £10
6n Airbag, never used! £15
6n Headlights with included Philips Colorvision Bulbs in Green now come with standard OSRAMS if I can find them, drivers side has a bit of damage, please see following pics £20 for the pair
6n2 rears with bulb holders and bulbs, excellent condition £15 for the pair - GONE
Central Locking pump, fully working £15
Wing Mirrors in LC6M, Electric , Passengers has replacement glass on, some small marks and scuffs on paintwork £10 per side
Full set of 5dr 6n2 Doorcards, with handles etc, need a wipe down, tweeters have extended wiring. includes passenger window switch but not drivers. no speakers or speaker pods, includes mirror switch re-wired to fit 6n, handles do need a rub down as rubber shit coating is coming off £35
FULL 6n2 Dash conversion, well 99%!! everything here you need to transform the dash of your 6n plus a few luxurys.
Dashboard with Airbag
Custom White lipped Binnacle Cover
6n2 DUAL cupholder (one needs a replacement spring)
6n2 GTI gearknob gaitor
Lupo clocks on 113K
6n2 Heater Matrix
Modified Heater Matrix Loom
All Connectors re-wired, either add them to your existing loom or use them as a guide
Modified ashtray to house the window switches
probably forgotten what else
ALL YOU NEED IS THIS - a peice of ducting that sits above the heater matrix for the windscreen vents.
this bolts straight into post 97 polo's, pre 97 polo's need different clocks connector and it re-wiring
£150
Full set of 6n2 Red seats, Fronts have swapped bases with height adjustment, need a clean but will come up brilliantly with a carpet cleaner, a great alternative to GTi seats. No rips or tears, just need a clean £50
Full set of BBS Solitudes 15" et38 6J 4x 100 two in white with lots of tread on tyres, two in chalkboard/matte black, freshly painted, see following images £120 - expecting a deposit on monday 3/10/15 Deposit Taken Keeping these now
6n Valver rear bumper in LC6M couple of scratches scuffs either side, but no cracks or gouges, has a melted part where exhaust blew against it, but not really noticeable when on car £30
6n Valver front bumper, has some slight damage to driver side and has a crack, but definately fixable, one of mounting points on rear is torn, but wont affect mounting it, paint is slightly cracing on drivers side, includes all grilles with no damage to them £35 SOLD
you can find a load of pics and information in my thread here - http://www.clubpolo.co.uk/forum/index.php?showtopic=322731&hl=
thanks for looking :)
Edited by R10tz0r
Just to add I am open to offers, do need space now for my inevitable hoard of valver parts ;)
