Breadvan Mk2f Top Mounts
Quick question what top mounts do you guys use when you have a real low breadie ? The ones i have are the original and on full lock they lift right out of the inner arch mount under the bonnet ?? If you know where can i get some ? Any help would be appreciated.
  • Views 529
  • wizardmanjm
    wizardmanjm
    I know you said you do mean top mounts and I could just be confused by your explanation but I think you mean top caps? If so the originals come out when lowered as if they are floating above the turr
I do mean suspension top mounts ie plastic caps he shock bolts to. Cheers !!
If so the originals come out when lowered as if they are floating above the turret..some 6n top caps will help it sit flush and can be bought from psi tuning. They have a rubber surround instead of nylon so are quieter if they hit down as well
