mk3 rub strip - clip on?
Hi,
I'm trying to refit a rub strip to a mk3 polo coupe - it's the black plastic strip 1/3 up that runs the length of the door that all mk3 polo's have.
It came off - as it got knocked, currently there is a fixing strip glued to the door with ribs, and somehow the rub strip clips or slides on?
The problem is we just havn't got the knack of how to do it
Can someone help?
Joe
  • Views 770
Should just slide on like you did, you can pinch the top and bottom to protrude the rail bit away from the door more then slide the end of the strip onto the rail.
This is hard to show using words, I'm sure it's probably just being stubborn because of being a bit mishaped or something
EDIT: I would video it but I took my rubbing strips off a while back
Edited by wizardmanjm
These are glued/taped aren't they?
There's two parts and the ribbed bit is glued to the door where the outer section that you can see just slides on to it
I see.
