Uprated headlight loom for 6n2
Hi, Does anyone know where I can Get an uprated headlight loom for my 6n2? preferably plug and play,
Thanks in advance.
  • Views 624
The aftermarket headlights by depo and fk (projector style etc) tend to come with them so may be available seperatly BUT these are not ideal. Reason being that it connects to the headlights plug on the housing, meaning the weak part of the circuit is from that connector to the bulbs.
I had a harness on ours before I got the gti headlights, it was a very basic harness and I used spade connectors straight to the back of the bulbs but worked very well, and I only used cheapo bulbs.
I'm sure there are ready made harnesses for sale on eBay for h7 bulbs, and if you wanted the main beams relayed too then get one for h1 bulbs.
Remember that the ground wire going to the bulbs is very important too (if not more important) so make sure that it's a good connection and goes to a good ground, I recommend using the factory ground posts under the passengers headlight. The h1 has its ground wire on its holder, this is the weak point of h1 bulbs design because if it's not seated properly it won't have a good connection and will over heat and cause the bulb to fail so bare this in mind if you plan on using higher wattage bulbs.
My 'favourite' supplier for auto electrical parts is Vehicle Wiring Products - you can download their new catalogue from vehicleproducts.co.uk
Regards
