Mk2f coilovers
Can anyone point me in the right direction of a cheap set of coilovers for a mk2f polo please ?
I know a lot of people say cheap ones can be very stiff drive but I don't mind a stiff ride as am use to it from when I had my novas slammed on coilovers
  • Views 905
  • Mk1 golf ones fit with a mix and match of parts and some fabrication. The fab part shouldn't be taken on by anyone that isn't good at welding and has less brain cells than a cucumber. If they fail you
From what I've seen the cheap ones are far from stiff, a mate had a set of ta's on his and the rears were silly soft. He ended having to buy stiffer springs for them
That's not good as I'd rather have them stiff as I think you can feel the car more when you drive
I've tryed eBay but can't seem to find any at all
Is there any of a make/model of car that suspension will fit ?
Mk1 golf ones fit with a mix and match of parts and some fabrication. The fab part shouldn't be taken on by anyone that isn't good at welding and has less brain cells than a cucumber. If they fail you will lose all steering and I've seen some absolutely retarded attempts by people at making them. Probably best to just stick with ones made specifically for your car, if there's non listed on uk ebay give german ebay a go
Edited by Mclovin
Yea the eBay ones are the cheapest around but they still need bearings fitted and all the back plate and brakes swapped onto them
DAMN! - the price of safety is expensive:-(
