6n2 GTI spoiler on 6n2
Hey, is it possible to fit a 6n2 gti spoiler on a regular 6n2?
if so how? just bolt it in?
  • Views 986
Yep put one on mine. There's 2x torques screws and 2 nuts then it's bonded on so reqs a bit of pulling. You'll need to either drill your boot for the outer nuts or cut threads off. The 2 torque screws are accessed via the screw holes as your normal high level brake light would be
Is it hard to drill?
how long did it take you to put yours on your car?
Interested in this also! Got one last week and need to fit it!
Took about 20 mins, I choose to cut the threads off as if you drill holes in wrong places even slightly your buggered. I used it with the 2 torqs screws then tiger sealed the rest and it was solid
What is the seal for?
sorry but I dont really know much about this so dont get annoyed :D
also what threads do you mean?
It's fine :)Tiger seal is to bond it on to the car. The threads are the bits the 2 nuts screw on to on the outer sides
ok thanks man helped alot :)
