Rattle can
Hi there few weeks ago my friend filled and sprayed the side of my car because of a massive scratch. Due to time restrictions and work he was unable to polish is after spraying.
I'm just looking for some advice on how to get rid of the Orange peel effect and should do it by hand or with a machine polisher? Thanks a lot
  • Views 759
It's safest to do it by hand - it's all too easy to go through the new paint if you do it with a machine, especially rattle can paint.
Try some polish on a cloth to stare with, but if the orange peel and/or overspray is very bad, some very fine 'Wet or Dry' soaked in water and with plenty of soap applied to the abrasive side then rubbed with hardly any pressure on it will probably sort it. - keep washing and checking it as you go though.
Regards
Wet and dry sand paper can work wonders to a rattle can paint job. I rattle can painted one of my wings and after a few weeks used 2000 then 2500 grit wet and dry to sand it back. After a hand polish and wax it now doesn't look that far off the finish on the opposite wing which was painted by a pro.
It isn't a quick process though but perfection takes time.
often theres not enough product on the car to do much flatting and polishing
if your mate is a bit handy like that it might be worth letting him do it as its pretty easy to rub through or burn the paint if you haven't done it before
