2002 9n rear disc conversion
Hi all, new to forum so go easy on me.
I have a very nice polo 1.2 s 3dr on which I would like to do a rear disk conversion. Is there anyone out there who could tell me what list of parts i'd need and if any other model vw could be used for the donor parts ie. Golf? Any info would be much appreciated. The car is on 16" GT rims so should have good clearance for calipers.
Gareth.
P.S. Great Club!!
  • Views 838
  • First Welcome to the forum. If you can't find a 9N with the rear discs (GTi or diesel models) then the normal donor car is a Mk4 Golf, then if you look in the FAQ's in this section, follow the guide
If you can't find a 9N with the rear discs (GTi or diesel models) then the normal donor car is a Mk4 Golf, then if you look in the FAQ's in this section, follow the guide, it's for the earlier models but they are very similar, if you have ABS then you'll also need to swap the sensor ring onto the new stub axle
Thanks Nigel just the answer I was looking for,
Gareth
