Cost of new windscreen and fitting for 6N2.
Hello all,
Car is a 6N2, 1.4, 8v, petrol, year 2000, 128,400 miles.
MOT not due till around April next year. Windscreen is damaged but I don't think an MOT failure.
My short story for the benefit of others: My own fault as wipers not changed in many years. I inspected them often but I'm not in good mental health and replacement of wipers sort of passed me by till it was too late. I was silly to think that if the rubber isn't torn then no damage can be done but I was wrong. Also I probably don't wash the car enough and that probably set up a grinding paste. There is scoring in arched tracks at the pressure points of the old style wipers. I've replaced with the new Aerowiper wipers so those pressure points are gone but the damage is already done. You can't see the damage in the rain but the low sun in the dry shows them up. Luckily none directly in line of site.
Certainly a lesson learned for me and I'll surely replace my wipers every year now. I'm fairly certain - I've read the rules - and I think I've just missed MOT failure stage. However best to be prepared.
What are my options if I failed my MOT? What's the cost of a new windscreen and fitting?
I seem to have noticed more stone chips too on the drivers side all of a sudden (maybe cos I've started looking). Was thinking can judder and jumping possibly cause stone chips or is that just silly thinking. Car has done 128,000 miles.
Many thanks in advance,
Simon
Edited by cosaw
  • Replies 18
  • Views 1k
If you can't see the marks in the rain have you tried just polishing the screen first?
Can claim on insurance, if you got Window screen cover, shouldn't be more than £75 and it doesn't effect no claims.
If you picked up a piece of grit in your chamois, and scratched the paintwork, would you claim that on insurance too?
Even if you decided to continue advocating banging in a spurious claim, some policies will affect NCB whilst others will impact the premium on renewal. Most insurers require disclosure of any previous claims (because a windscreen claim is a claim).
Why encourage this behaviour? The rising cost of motor insurance is bad enough; why add to it?
Not all insurance companies regard windscreen claims as an actual insurance claim. In fact I think it is a relatively new thing that is being introduced. I only learned about it last year when my sister was having issues with her car insurance over previous windscreen claims.
Regardless of that though if you need a screen replaced I'd rather pay £75 and risk a slightly higher renewal than spend hundreds at once on a new screen that could get smashed 5 miles down the road.
The point is, it's not an insurance loss.
Thanks for the interesting debate and comments. I'd be cautious about making an insurance claim. So to further the debate:
How much would it cost, me, if I replaced the screen myself?
I haven't tried this. It's not my area of expertise. I'm thinking that if I can feel the scratches with my finger nail then it's not going to polish out - am I wrong? If polishing can be aggressive enough then how do I go about it (and with what tools) without junking my windscreen completely anyway?
Costs will vary dependent on your location and size of business.
Ball park: circa £135-170 fitted.
Thanks for the estimate Paul. It's affordable I suppose if a necessity. If I add up the cost of the number of sets of new wipers I should have had by now that will help towards it.
Any further thoughts on how much a polish will help or how to go about it?
I would try and polish them out! If you cant polish them out and they are affecting your visibility, whether its raining or if the sun 'highlights' them, get a new windscreen! Your safety comes first buddy! I can claim for as many windscreens as i like without having an effect on my insurance but I've only had to do it once in 10 years.
Polishing is tricky, moreso as it's a forward facing window on the car. The bigest risk is cracking the glass as a lot of heat is generated whilst polishing, and the downard pressure is applied to the glass surface with a mechanically operated polisher, specifically designed for glass.
Another issue is distortion. Polishing glass (excessively) can create distortion. The deeper the scratch(es) the more polishing is required, ergo: the greater the risk.
A single scratch about 10" long can take about an hour to polish. The same amount of time for a scuff about 1" x 1". Decent glass polishing professionals will charge by the hour.
Try Glass Doctors or Glasweld.
Thanks for the further details guys. Much appreciated. I didn't know anything about windscreen polishing before now. I know the polishing won't get the chips out as they're deeper - though not horrendous.
Still wondering though if juddering wipers and large pieces of grit can create chips themselves? Personally I think there is not enough force but stranger things have happened I suppose. What do you guys think?
Surface pitting is common with any car that's been driven over 40mph.
Chips are usually from stones hitting it while your driving. If you have stone chips and the previously mentioned issue, just replace it mate. It will be worth it! Nothing like a shiney new windscreen!
What I would try is a change of wipers and some normal car glass polish first. For the sake of the £20 it will cost you it is worth a try. Then just keep on top of it over the winter and see what your MOT man says when it is due next year.
He might as well take a lighter to a 20-pound note; 'normal glass polish' will not cut any more than dirt and film. Even with a proper cutting compound (Cerium Oxide before you go reaching for T-Cut) and a proper glass polisher you'll be there for a very long time.
At least my suggestion he will have something to show for his £20. None of us have seen pictures of the windscreen to properly comment on how bad the scratches are, I'm just saying what I would try given his description. Plus I try and be more of a 'glass half full' kind of guy.
I try and be realistic, and I base my opinion on 25 years in the windscreen and glass industry.
The current level of damage isn't causing a visibility issue at the moment. I have new wipers fitted of course. I do feel though, from my limited experience - and the useful comments given here, that any type of polishing I can achieve isn't gonna cut it and would be money wasted.
Unless it becomes a visibility issue in the near future, I'm gonna wait till my MOT in the new year and then decide what to do then. Thanks to everyone for your time and advice - it's appreciated.
