Lesley the 86 breadvan
185/50 are like hens teeth unless you're prepared to buy yokos. 175/50 are around £50 a corner and I think I've seen 195/50 for around the same price. Not cheap I'm afraid. Have a look around at some new small cars running 14s and see what their sizes are, you could probably use something like they do and they'd be cheap.
  • Replies 142
  • Views 15k
  • Today I've been painting the first 2 of my mk2 golf steelies As you can see one in particular was not in a good way They look so much nicer with new paint and should look pretty mad wi
  • Don't worry I did, that's just when I put back on Thanks mate! I did the first couple of coats of base coat today so I'll try and take some pictures very soon
  • That does sound like a nightmare! Nah with mine the previous owner must have had a small accident which caused the plastic on the arch to crack and some flaked off. I used plastic bumper filler becau
Ok thanks, I'll have a look
Today I've been working on some more body work
My rear left quater panel was in horrible condition with a large dent, chipped and poorly repaired paint and two drill holes in it (the previous owner seemed to have no problems drilling holes in the car!)
I started by getting the dent out with a heat gun and GoPro mount which worked a treat
Before
9CDC7D96-2928-4547-B6A9-80CE07ADAC98_zps
F8C50643-A500-48E1-B91E-3B1E6774D95F_zps
0B1C9B29-BC41-42AC-922D-AA97B104BFB3_zps
After
85FAA55A-3409-4DF7-BAC2-40AF182BF5DC_zps
Then I sanded down and filled the drill holes
81162037-8C80-46DA-A512-76E0F1DAC471_zps
8E18B1D9-22A4-4D90-B6FD-5BC2283E700E_zps
Filler primer
BC6FD38F-21B1-4537-AA73-1A7CA997CAEB_zps
(Primer)
Base and clear
93FB09A2-426E-4430-9286-23BFE44047E4_zps
I just need to properly buff it up now
Also 1986 or 2008
8643253E-D814-405C-9B22-41206DDB8EEF_zps
F36BC3A7-0E8E-424A-A800-C2775558B0F7_zps
nice to see youre trying to make it right rather than the stupid rat look /plastidip nonsense
Yeah I've never been too sure about that whole scene, my aim is to get it nearer stock condition before I do anything else
Also I just won a bid on a Sony mex bt2500 head unit, does anyone have any suggestions on how/where to install front speakers without ruining interiors?
Update,
Today my head unit and speakers arrived!
A2F35593-7E62-4031-83C0-08629E240521_zps
I removed the old rear speakers but these surely aren't stock are they?
035EBE52-8E22-4812-B0D1-1AF83E94A863_zps
The front looked much more original
907072F1-0930-4F25-ADC8-AF018E0DC3CF_zps
Good old eurotec
35B29841-370C-4202-9468-91813B1FB99B_zps
Lovely stock sound system!
77FD7D51-C088-482C-A9E7-0E30EA9CFE1F_zps
This looks far better from where I'm sitting, I'll actually wire them in soon hopefully
7DA96418-6B75-49D5-9043-CC6D83AB4EF9_zps
Also I've decided that I love the original chrome trims that some mk2s were blessed with but due to original ones being difficult to find and expensive I did the next best thing
739DBEEB-A602-4FE9-B415-A6C53F8E2180_zps
Chrome vinyl and trim
I started with the grille
440FB082-A669-40F5-B68D-C0D6412A7343_zps
737ADB73-857C-4671-94AC-057965998B17_zps
63C86957-9F21-48E4-AF49-F3D940583265_zps
BA237A8F-D461-43D9-AF2A-C28183BF8D2F_zps
Maybe it's not for everyone but I love it!
I also tried one centre cap but I'm not sure if I'll do all of them
4C0AB2ED-B187-41FA-B69F-2982179DD946_zps
81BF4631-E476-499F-9B9A-7575E4797BCE_zps
EF8FC7C7-0A94-4326-9F1D-C25D1AB99D9F_zps
That's about it for now
Grille looks smart but I can't see those wheel trims lasting the weather. What is that you're using?
Thanks, yeah I wondered that but I guess I'll see, it's just chrome vinyl that I bought off eBay so nothing special really
not keen on the chrome , i think they just had silver paint on the grilles?
I used silver pin stripe and i love it
I love the chrome strips on the grille, obviously paint may be a better option for the future
On new cars I'm not keen on chrome at all but on older styles I think it looks really good
You can get chrome strip just 3mm thick, i think that would be best for the grille, same effect (the originals were polychromed).
I don't think that centre cap has come out as well as it could have, but i think you're onto something if you don't wanna pay the £100 i got when i sold a set of stainless ones. Firstly i'd sand the edges of the VW smooth and rounded, then fill the sections with silicone and wipe around it with a finger. The aim being to replicate the shallow, rounded recesses of the stainless ones. Then, using a hair dryer or heat gun, you should be able to apply the film so that there are no creases or bubbles.
Mine were particularly shiny as they'd been stored in a loft since new, along with the wheels, but most have lost their gloss a bit and the plastic finish should give a very similar effect..
I was just mucking about with that one really, if I was to do them all I probably would do something similar to what you just suggested. Those stainless steel ones you had is exactly the look I'm going for, with those steels they look mint!
Quick question, if I was to replace my front left wing (because mine is pretty dented) by removing the welding and bolts, would I need to get the new one welded again or would the bolts be enough to securely keep it there? What have other people done? Any info is useful
It's not welded. It can be stubborn to remove only because of the seam sealer (the bolts behind the door shut area are usually covered in it, so you have to tap the socket fully onto the heads with a hammer once it's aligned).
Really? Mine seems to be welded at the windscreen end of it, are there any instruction on how to remove it anywhere?
good work mate. do you have a spare individual alpine speaker left over? as you put one in the dash. I'm me if so cheers
Thanks! I do indeed but I'm not sure if I want to sell it as I may use it for something else at some point, pm me an offer
Today I've been doing some fairly sizeable jobs that I guess I've been putting off,
I began by finishing off my rear quarter panel to get it shiny
First I wet sanded it to get the clear coat smooth
2B7940CC-836E-46A1-AFE8-E1BB2F660AA2_zps
D6E865B0-8EE3-4DB9-88A4-751C95795385_zps
Then polished and waxed it
05190C8E-5C6F-4D06-9BC4-C787420661E3_zps
D26A6171-55F1-4F5D-8573-889B029BA5BD_zps
853CD75D-FB05-48B2-AB04-A8A8B6543C73_zps
9E9D7936-B8C2-4197-988A-B6D57E792C94_zps
After that I painted my air filter cover in the body colour
EDECC8C4-3EC6-40CD-A15B-FE0B33E2FB74_zps
Priming
FC15C0CC-CDFD-4949-94E1-DFFA623803A0_zps
Sanding
6A6E7D0F-F0EC-4A8B-B184-62AB6C642A17_zps
Base
162FB2E7-EC3F-4FD9-8514-B9C4AFD6366C_zps
7B78818E-85F9-40E6-B925-5E9AF800195B_zps
Clear
741EDF3C-BD69-42A8-A570-75BC74E5F4A4_zps
B7B38B44-747C-42C7-8AE1-089A8C420548_zps
597548BF-0FBB-4CC7-A90B-5C4B1DC6E906_zps
Now I really need to spray my rocker cover
Finally and most importantly I began prepping and paintingmy bonnet
5FCCCDBC-1122-4C6E-8465-CA7940E65224_zps
Priming
C17FDC5C-DC17-498A-9CC9-AD60C0960FDC_zps
Wet sand
93FD59D6-6F0D-4CE8-AC98-BC2F5E3F99F2_zps
Base
85B130D3-BD0F-4FB1-8FDF-98D09A16C61C_zps
058CF43F-D5C6-4F4B-B38A-4E717531DD18_zps
(Clear)
Wet sand
F3E0B200-D5FB-44AC-9CCF-44ABF4BEECDE_zps
Then polishing and waxing gave me this
C40425EE-3375-4E54-967C-C894CFC6346A_zps
All in all I couldn't be happier with everything today, the car is actually fairly presentable now
Cheers now
Looks very good mate. Top job painting, the last bonnet picture looks streaky or is that just the picture?
Normally I would say the body coloured airboxes look crap but yours being a dark navy colour anyway it actually looks quite nice
Thanks mate, it's just odd lighting or something like that. Yeah I wasn't too sure at first but I thought because it's quite dark it would be ok
Does anyone have any idea where I could buy some oem hubcaps for the bready? Does anyone have a set they wouldn't mind selling?
The only place I've reliably seen any decent sets is http://shop.volkswagen-classic-parts.de/vwcp/polo-derby/polo-ii-2f/chassis/rims/
But I hate recommending it as they seem to have a flat rate on the postage to the UK of 26, even if you just buy a bolt :-(
Other than that, start a wanted thread and keep an eye on the old auction site ;)
That's very useful thanks mate, I'll do that
