Opcom with VCDS
Hi,
Newbie alert. I've acquired a 98 polo 1.0 with an airbag light on. My Bluetooth OBD connector doesn't play ball and I don't have vagcom. I do however have an opcom cable - is it possible to use the opcom cable with the VCDS software or do I need to get on eBay for a vagcom cable? Trying to avoid the unnecessary expense just for turning a light off.
  • Views 2.3k
Don't worry i bought a £5 eBay cable and the light is now out. Intermittent high resistance so probably the slip ring - will see how it goes
