Polo 6ns ODB port missing wire?
hello guys!
i ordered a fault code reader for my 1996 6ns. so it arrived and i wanted to test it. i found the odb port, but seems like the wires are missing. Where could i connect my code reader? i attached some photos too. anyone see the cable i looking for? :D
thanks a lot!
post-922134-0-35546600-1447341654_thumb.
post-922134-0-88776500-1447341657_thumb.
post-922134-0-08322900-1447341661_thumb.
post-922134-0-20308700-1447341664_thumb.
post-922134-0-95071000-1447341667_thumb.
post-922134-0-82138700-1447341694_thumb.
  • Views 791
its behind the ash tray....
No it's not ! it's in the first picture :) there will only be 3 wires connected to it, Power, Ground & the "K" line, the K line goes to a communing junction block on the rear/top of the fusebox
yeah on the first picture there is this black port. but there are no wires in it. What Wirecolour should i look for?
The power is a 0.5mm Red/White wire Pin 16, the ground is a 0.5mm Brown wire pin4, & K line Grey/White 0.5mm wire pin 7, there might be a Yellow 0.5mm wire coming from the communing junction block I mentioned above and that goes to pin 15
well thank you so much, i'll check it in the morning
