Which Torx sizes are used on the 6N?
Hi all,
Having been asked what I want for christmas and getting fed up with my set of Torx bits i'm going to ask for a rail of Torx bit sockets.
What is used on the Polo 6N? I want to get a set with a good range for the Polo.
I'm a bit unsure, as I have only had it a few weeks, and only taken apart interior stuff, generally smaller.
$(KGrHqIOKnME62f7!TpRBSYmeJ5qRQ~~60_35.J
Thanks,
Matt
  • Replies 9
  • Views 2.1k
I'd try and get a set that ranges from T8-T55 if you can. Saves you being stuck if you have to work on something like a BMW later on down the road.
From memory though the 6n has a few T10 screws inside and uses T20, T25 & T30 for some external parts.
Thanks for that - very helpful.
Are there any bolts with a Torx shaped head, that you'd need Torx (female like) sockets for? That seems more common on BMW/Merc to me than VW but i'm probably wrong :paranoid:
1/4 inch T6, T7, T8, T9, T10, T15, T20, T25, T27 and T30 should cut the mustard then.
Perhaps 1/2 inch T20, T25, T27, T30, T40, T45, T50, T55 & T60 also?
Fairly sure there aren't any above T30 and as most are used on panel screws etc there isn't any great torque involved so 1/4" or 3/8" should be sufficient, the other useful special tools would be a M8 & M12 multi spline tools ( driveshafts & cylinder head bolts)
Thanks - that range it shall be then, and Britool Expert as I think the quality and price of their stuff is great.
I was only looking at that 1/2 inch set to get some larger ones, and the 3/8 inch set is much more expensive and contains fewer sizes.
I'll also try to find some decent spline tools - thanks!
Most of my Torx bits are 1/4" and they are good enough as they are never 'that' tight.
BMW and Vauxhall are the ones that mostly use E-torx so no point buying them if you're just going to be working on your 6n.
Not rail mounted, but my latest bit set was one of these:
ebay
No complaints yet and I'm more than capable of damaging them, but it's cheap enough that I can break a few and then buy another set.
I too used the same set as yeha, can say I've had it over a year and used it a billion times and I am very heavy handed lol been perfect so far. Only downside is if you carry that box and then open it again they will not be as nicely arranged as in the photo and that gets annoying lol
Looks decent enough for a tenner.
Thanks for the info - won't bother with E-torx then as I suspected... not till I get that M5 anyway ;)
Looks good for a tenner, but I like Britool, prefer the bit mounted/fixed to the socket holder, and already have lots of Britool hex bit sockets so will just add to that :)
Edited by Baine93
