Eibach rear camber shims
Is there much advantage to having these installed with regard to handling to make the rear geometry different from stock?
  • Views 538
yes.
After lowering any of my Polo's I've always had the rear geometry measured and then fitted these to adjust the rear toe and camber back to standard - made a massive difference and much less twitchy on the rear, especially in the wet.
OK, thanks for that. I will keep that in mind if I do decide to lower the breadvan.
Regards
Phil
