Polo mk2f coupe
Year: 1991
Mileage: 130k
MOT: June 2016
Price: 500
Here you have a one of a kind Polo coupe!
It runs. It drives. It stops, depending on how hard you press the pedal..And it turns off..
Its a rare capri green colour, but what makes this paint unique is all the chips and paint flake there is..One of a kind!
This car is ideal for students living away as it has a roof rack so all your gear and boxes of beer can go on top..
Its been lowered on a 50 mm kit so the ride is nice and stiff, ideal for going over speed bumps at 40mph and your exhaust won't scrape! Believe it or not the car can go faster..
Under the bonnet theres a mighty 1.3 engine! It has covered just over 130k miles, has a light weight rusty cam cover, pancake for an air filter and a screemer pipe by the looks of it..maybe theres a turbo in there somewhere too..
On the inside is a whole different story..
Seats have wooden beads on so if you suffer from back problems this is the car for you.
No rear seats, but it has a one of a kind boot build, and students, heres more room for beer..
Now the poo bits..
Windscreen has a scratch on the passenger's side, as if someone used wire wool as a wiper, but if you don't look at the passenger's side then you cant even see it..
Oil light flashes but doesn't loose oil, when you shift or in neutral it stops so it could be a type of shift light..
The paint is unique as you know so don't expect a show winner here..
The biggest dent is on the passenger's rear arch, look at pic, but it's good aerodynamics for when your going at high speeds..
Radio is present but not wired in..But if you have a lovely voice then thats better than Kiss 100..
I've owned the car since May just for work transportation and it's been spot on to me..
MOT till June 2016
Any questions just ask on here or text 07879637799
post-914148-0-10438300-1447462904_thumb.
post-914148-0-75439000-1447462921_thumb.
post-914148-0-99886500-1447462924_thumb.
post-914148-0-93941200-1447462927_thumb.
post-914148-0-26034100-1447462931_thumb.
post-914148-0-28131000-1447462934_thumb.
post-914148-0-48755200-1447462937_thumb.
post-914148-0-37553300-1447462940_thumb.
  • Views 477
4 or 5 speed ?
4 speed
