vw polo mk2 battery tray
Hi i've taken the battery out of my e reg mk2 polo breadvan and have discovered an hole in the panel below it looks about 3 inches long and about 1 inch wide. what would be the best option for this type of job would fibre glass filler be ok or does this need welding or are there better products out the to use
i've attatched a couple of photos from under neath dash and on top of panel . p.s from the pics the panel looks rusty but thats just dried out grease and old underseal the panel feels solid other than the hole.. regards mike
post-919640-0-33250500-1447687727_thumb.
post-919640-0-34990100-1447687783_thumb.
post-919640-0-08063600-1447687909_thumb.
  • Views 3.4k
Well, the best option is always to weld it up and then protect the metal properly. But, as a patch up job for mine:
I cut the remaining rusty metal out, sanded it back as best I could, then fibreglassed over it. Worked quite well, but I am getting a leak in to the cabin again :(
all those little brown dots will likely be pin holes once cleaned up
the proper repair is cut away the rust and weld in new steel , but if you cant do it /afford it then fibre glass over the clean metal would seal it temporarily until the time comes when you can repair it properly
