Wheels and 1.8 spi Throttle body mk3 golf
mk2/3 13 inch steel wheels: These are taking up space and I need them gone, Tires are bad from toe when suspension was changed a while back, the two rears may be legal but all have a bit cracking I think.
Golf 1.8 spi Throttle body: This has had the connection bits swapped for the polo 2f spi stuff so can be threw straight on and plugged in the same. The inlet manifold port matches perfectly with the butterfly port on the throttle body so flow would be better, I heard its better to use the injector from the 1.3 monopoint as it uses less fuel but does not compromise the extra poke.
Only problem with this is the throttle cable pulls from the front so a home-brew cable would have to be made or a cable would have to be made by speedy cables or a similar company.
Collection from TW19, Will not post either but if push comes to shove then I don't mind someone organizing a courier for the SPI
John
  • Views 692
If somebody comes and gets my steel wheels I will give a bunch of other bits too. I have:
mk2 standard 3 bolt cam cover (2 bolts too, dont know where the other one is)
some mirror adjuster knobs and gaitors
Interior door handle trim surround
Adjustable passenger wing mirror (Great and full working condition)
Mk2 pre facelift haynes manual (never used and came with car plus mines a 2F)
SPI spares and maybe a 1.3 SPI manifold somewhere
Probably more bits I just cant think of, If someone can get these wheels out the way they can take the lot, I could chuck em but I figure it would be a waste
Can someone Remove this please, Its all getting thrown now
