Knife edged crank
What's the benefits of a knife edged crank?
Does anyone know how much it would cost for a 6n2 gti one?
  • Views 904
  • prankstar2003
    prankstar2003
    Lightening as above but also reduces the surface area and thus resistance as the crank passes through the oil. During the process the crank may also be more finely balances too (no that it's likely to
It's more of a service they can do to your existing crank I believe, something to so with the counter weights?
Reduces rotational mass,
Engine revs up allot faster but reduces engine braking ability.... same as lightening the flywheel.....
Good for race cars...
Little to no benefit on the road.
every little helps? or not?
Does the knife edging also flick off the oil more easily again reducing rotational mass. In big racing engines, windage trays and dry sumping can mean a gain of some horsepower simply by keeping oil draining down through the engine to a minimum.
Regards
Phil
does knife edge not flick up the oil as well ?
does the crank actually dip into the oil in the sump slightly?
Lightening as above but also reduces the surface area and thus resistance as the crank passes through the oil. During the process the crank may also be more finely balances too (no that it's likely to be way out from factory anyway). Probably no noticeable difference on a road car but if you're trying to squeeze every last bit out then go for it.
