6n Bits n Bobs
Looking for a few bits to tidy up my 6n. List is ongoing, will add to it as I will likely discover more problems. Can collect stuff within 50 miles of WN7 else things'll have to be posted.
- Driver side window mechanism
- Number plate light, need both connectors (here's why)
- Driver side glovebox
- Passenger side glovebox lid
- That bit that holds the fuel flap closed
I also have an engine cover, but can't figure out how it fits on the engine. If anyone has the brackets/bolts/whatever that I need, it'd be cool.
Edited by Vio
  • Views 534
Info on fitting the engine cover 1998model_engine_cover.pdf
Hi I should have all the parts you require except the manual window mechanism I will have to check as they are stored in my unit if you want them, I am in wiltshire. I scrapped my 5 door 6N (to a bare shell so have all the little parts clips etc) it had a dark grey interior If wanted I can send photos cheers Ian
That pdf is brilliant. Out of curiosity, would the process be the same for the mk2f?
@ian - am a bit too far to collect but will pay for postage. On any other car I wouldn't mind a look at the interior as well, but I wanna keep mine as close to stock as possible :p
Also if you have the interior courtesy light, as mines a bit iffy
I'd imagine it would be similar to fit it on a mk2f
I will have a look for you it wont be until next week though posting is no problem
