Polo GTi oil sump (ARC)
Hello all!
Recently cracked my sump on my GTi engine (Code ARC) and I'm having trouble finding a replacement.
Any ideas? Can I use one from a different engine code?
  • Views 994
Popular Days
You could use a steel sump from a 6n, should be easy enough to find and they are a little tougher than the alloy ones if you are low. You would also need the shorter sump bolts from the 6n too.
