year 2000 polo 1.0 E
does anyone know where i can get a gear linkage kit as it is very difficult to find the gears on my new car
  • Views 418
Are you sure that what the problem is as they suffer with wale peddle boxes also.
As above the pedal boxes are prone to cracking.
The gearboxes themselves are also prone to failing. The oil leaks out of them and they run dry then the bearings fail and the shafts have massive play making gear change difficult. This also puts extra strain on the cables for the selector meaning they stretch etc.
Hopefully though it's not that. There is adjustments for forward and backwards and side to side. This is done at the gear box. The car does need to be raised up and is much easier with 2 people.
