6n2 Polo Removed Clocks, Now Airbag light is on
Hi,
I removed the clocks in my 6n2 recently because they had broken.
When I put them back in the airbag light was on.
Any idea why? And is it just a case of getting someone with a CAN obd lead to clear the codes?
2000 Reg 1.0 6n2 btw.
Thanks,
Matt
  • Views 608
Did you disturb the airbag connections when you replaced the speedo unit? as this will of set a fault code that will need deleting, and as you have said it will need a CANbus capable cable, where abouts are you?
Not that I'm aware of but It's fully possible. I'll look into somewhere near me where I can get it sorted. My usual mechanic doesn't have the right diagnostic tools for the job.
Ireland, Unfortunately :tongue:
Thanks.
