Wheels!
I need some decent wheels, looking for something 15" not sure what ET or what J to run any advise?
  • Replies 20
  • Views 890
  • kwijibo_coupe
    kwijibo_coupe
    BBS RA, BBS RZ, VW Le Catellets (rather rare) & VW Estorils, are a few of the standard 15" VW alloys that go well on an older shape VW I think. They all (apart from the Estroils I think) come in s
  • wizardmanjm
    wizardmanjm
    It's the rear where your going to find problems, 6j can be done with a thin tire and as close to the original offset as possible but 5.5j works best really and less chance you have to attack your arch
  • I've seen other wheels in 15s on a breadvan, but it just looked weird... The steelies seem to be the only suitable large wheels (in my opinion of course). I run 14x6 but I have a narrow and thin tyr
What car do you have?
15s will work with small tyres but you'll struggle if they're too wide or too much of an offset, especially with a breadvan.
yeah its a breadvan, i was thinking this when i was looking, hardly any room on the front, trying to find wheels that would fit its so hard and getting stressful, I'm a mechanic but I'm not schooled on wheels i dont really have to think about them sorts of things haha!
It's the rear where your going to find problems, 6j can be done with a thin tire and as close to the original offset as possible but 5.5j works best really and less chance you have to attack your arches
thanks again, 5.5j it is don't want to go rolling arches, I've got work colleagues that can do it but don't fancy it really
Yeah best to leave the arches really as the rear isn't exactly an easy to replace panel, I know you said you want 15's but 13's don't look small with the right height and a low profile tire. Then you have the choice of bbs RA'S, you can get those in 14 inch as well but you will have a hard job finding them.
Only 15s I think I've seen on a breadvan is a one with g60 steel wheels and it does look very nice but I suspect much wider than that will give you problems
I run 14x6 but I have a narrow and thin tyre. Still get the odd scrap too. Stick to 5.5j and you'll be fine.
will get looking as you say a smaller wheel with a low profile tyre would look good thats what ill do, just glad I've got somewhere to get advise, having a workshop to do the work is so good, got loads done already as its sitting in work now until when I'm happy its all sorted, sealing underneath this week
anyone got any wheel makes or suggestions?
would like to see some pictures of the car, you should get a progress thread up when you have some time, only wheels that come to mind off the bat are BBS RA's and various steel wheels from the vw parts bin. There are a selection of vw alloys which you could get from mecatechnic.com such as silverstone's and hockenheims
I'm trying some Rial mesh wheels which look very nice but its a trial really and if they rub ill be removing them, I will let you know if they are good
i will start taking photos of progress :)
thinking mini steelies with abit of a stretch, refurb and polish shit into the rim :D
Sounds like a decent plan, you can also get chrome trim rings on mecatechnic so they have a sort of polished lip, looks good on gt steel wheels
MINI, Renault or Vauxhall, really.
I can vouch for BBS RA's. Look nice with my paint.
I quite like the ATS Classics, but they always look better in a larger width, gives them more of a dish. ATS Cups will also look good.
BBS Mahle's and BBS RZ's look sweet too.
Just do yourself a favour and don't ruin the arches. You'll regret it ;)
BBS RA, BBS RZ, VW Le Catellets (rather rare) & VW Estorils, are a few of the standard 15" VW alloys that go well on an older shape VW I think. They all (apart from the Estroils I think) come in smaller sizes too so it might be worth looking into them.
In my opinion 14" is really the biggest wheel you want on a mk2 breadvan for looks and/or a choice of tyre size so they don't give you scrubbing issues.
This might be a dumb question, but are the rear wheel wells different on the breadvan?
I read about people having problems with various wheels all the time but on my coupe I have 15x7" wheels and have never had any issues
It's the shape of the rear arches. They don't allow for wide wheels at all.
Oh right :) just had a look on google and I see what you mean. Can't believe I never noticed that until now.
Are the inner arches flat at the top too? Or just the outside
Also, I found a pic of a bready with some mini wheels, looks pretty nice IMO.
http://i762.photobucket.com/albums/xx266/bryce1992_24/DSC_0019.jpg
Yeah, seen that one before, minilites do look real nice on them :)
Inner arches? If I am right with what you mean, the bit you can see of the outer arch is the lowest point. Inside of the arches is about 4 or 5 inches higher, so large wheels CAN fit, but you would need stiff suspension if the rolling radius goes too high. Like I say, I run 14x6 wheels with a narrow tread and small wall. Rolling radius is about the same as the standard 13x4.5 wheels I had, but I still get the odd squeak thanks to them being so wide :( (and the fact I am running stock suspension).
Those wheels are minilights made by various manufacturers fitted to classic mini, bmw mini, mk1 & 2 escorts, chevettes plus others
