Replacing 6N2 doors
Hi all,
My drivers side took a little damage to the bodywork recently. I've sourced some new doors. Just wondering how hard it is to swap them over.
Actually mounting the doors shouldn't be a problem. I'm just worried about the central locking, how do I remove the lock barrel and install it into the new door? Are there any other things i'll need to move onto the new door? If there is, advice on what they are and how to do it would be appreciated.
Cheers,
Jeeves
Edited by Jeevsz
  • Views 538
The handle with the lock barrel is held in with a single torx screw, remove that, then the handle will slide forward then it can be pulled out of the door :)
Awesome, I'll probably be giving it a go tomorrow. I'll let you know how I get on.
