Volkswagen Mk5 Golf Gti Edition 30
Hi,
For sale I have my Tornado red Edition 30, build no 1505 which I have owned for almost 2 years. Genuine reason for sale, downgrading so I can put some cash towards a house.
PRICE: £9,950.00
2007 Vw Mk5 Golf Edition 30 (#1505 with plaque and VW certification) 3dr, DSG
MOT until Nov 2016
118k on the clock - Don't let this put you off, see below service work and price has taken this into consideration.
2 Former Keepers (Both previous forum members)
2 Keys (Main 1 has brand new badge)
Private plate NOT included - In the process of being taken off by DVLA
SERVICING
Full VW Service history up to 98k, then since then then has had 2 services by Volkswagen specialists. Within past 6 months following has been done:
Inlet and valves removed, cleaned de-coked and brand new valve springs (Golf R) fitted
Brand new Tappets
Brand new rocker arms
Timing chain
Cambelt
Head skimmed with new head gasket
Injectors ultrasonically cleaned/tested and re-fitted with new O'Rings
New oil pickup pipe (Common problem) and crankcase breather
New in-tank low pressure fuel pump
New Diverter Valve
New PCV valve
Turbo refurbished by Owen Developments with upgraded bearing (not a hybrid)
PERFORMANCE MODIFICATIONS:
Revo Stage 2+ Engine Map (Around 360 bhp and 380lb torque)
Revo Induction Kit
Eurojet Front Mount Intercooler
Golf R valve springs
Autotech High Pressure Fuel Pump internals
RS4 Return Valve
BCS 3" Powervalve turbo-back Exhaust - Quiet when cruising and sounds amazing on full boost
Revo Stage 2 DSG map (Complete override in manual mode)
Air-con has been fully removed, shorter aux belt fitted.
BRAKES/HANDLING:
FK Highsport Coilovers
H&R 28/24mm Anti-Roll bars
VW Racing Droplinks
Superpro Anti-Lift Kit
Brand new Rtech Rear Strut Brace (Not yet fitted)
Revo Engine mounts
Tarox B360 10 pot Front calipers with 2 piece 360mm Front Discs and Goodridge braided lines (Over 3K worth of brakes)
Rear Brakes have Feroda Pads
Full brake System high pressure bled with ATE Racing Blue
H&R 20mm Rear Spacers
Brand new tyres all round (Budgets as it is winter)
INTERIOR:
Custom Machined Gti Footrest
Carbon DSG Paddles
RCD310 Headunit with bluetooth
Half Leather/Tartan Front and Rear heated seats
Half MFD
EXTERIOR:
Genuine carbon fibre weaved front Vw badge
Puddle Lights
Heated Mirrors
US Spec running lights (I can turn this off on Vagcom if not to your taste)
Open Front Fog Grills
Brand new genuine Gti and Edition 30 badges on both front and rear
SPARES:
Standard suspension
Standard intercooler
Standard anti-roll bars
Standard Fog Grills
BAD BITS:
Front top mount has just started to knock ever so slightly - I will replace these if asking price met
Boot will not open, been told it needs a new solenoid - I will replace if asking price is met
Drivers side front arch has a bit of paint chipped off on the lip, not major
Note - I have sent off for the private plate to be taken off the car by DVLA and waiting back from them. Should you wish to purchase and I haven't received docs back, I will happily take a deposit and garage the car until received or come up with some kind of agreement.
Car puts the power down through the front wheels very well, over the summer I was running the front wheels with Toyo R1R semi slicks and it was amazing traction but now swapped back to normal tyres because of the weather. You will struggle to find a quicker road going car that's still suitable for daily use (I drive this to work everyday!).
Reason for sale is because I am looking to buy a house and therefore downgrading, new car purchased already.
Located just outside High Wycombe (HP10)
Any questions, let me know - Drop me a text or give me a call (If I don't answer then I will call you back)
Harry
07818116531
Edited by haz911
  • Views 870
Sold!!
