BBS Rz - To buy or not to buy?
I'm thinking about getting a set and was wondering how they would sit.
Might run 195 45 s or 175 50 on 15's. Not to keen on running 165/ 45 on a 7j, bit too much stretch for my liking.
My only concern is if they would give enough clearance to avoid rubbing. Anyone got any pics of their polo with a similar set up? Or just have experience of how they will sit?
Jeeves.
  • Views 563
First off I'm assuming you're fitting them to the 6n2 in your picture?
The offset on them is ET24 if I'm not mistaken. So compared to standard it will be like having a 14mm spacer and also the extra inch in width.
With a 195/45/15 I can't see there being any issues unless you are silly low.
Hopefully someone who has fitted them to a 6n2 can advise better.
Yeah it will be the 6N2 in the picture.
Ahh I see, that's helpful. Just out of interest how do you convert the offset into what the extra spacing will be?
Cheers,
Jeeves
Standard offset on a Polo is ET38 usually. It will say on the alloys themselves.
So something with an offset of ET24 will stick out 14mm more than one with ET38.
Makes sense... Cheers
