Remove individual window switches from trim (6N2)
Hi everyone..
I need to remove one of the individual switches from my drivers side electric window switch. I have the whole unit out of the door card, but need to get one broken switch out and replaced with another single switch that I'll salvage from another unit.
I can't seem to get it out, tried prying at it with a screw driver but it only caused damage to the unit housing.
Any help is appreciated,
Jeeves
  • Views 3.5k
The manual says " Push window regulator switch downwards out of switch housing" Looking at a spare switch I have, there are 4 tiny lugs(2 ea side) that are 5 & 20mm from the front edge of the rocker switch, so you might find a small instrument screwdriver at these points will assist in pushing the switches out of the housing :)
Got em.... Stabbed myself in the process but I'm ard as nails so i'll live :L
Cheers Nige
