1.4tdi 6n2 vac pipes
Hope someone can help, changed the cam belt yesterday and on rebuilding it I found avacum pipe off.... The 3 silver pipes that run to the drivers side it's the top one that just looks lost.... Please help as it's holding back..... And worse still it's the wife's
  • Views 10.9k
That's great thanks.... Says it goes to the pipe between the maf and charge cooler... But can't find where
I can't see any pictures of where the connections go to but here's another fitting locations 6N2 TDi Fitting locations overview.doc
I assume it's the connection in the red circle ?
post-36925-0-40366700-1450811057_thumb.p
if so the thick pipe it's going to is the pipe from the air filter to the turbo charger inlet
Yes thank you so much, found it earlier.... Hidden below a sensor on the turbo intake pipe.
Great for help on the forum here, many thanks
