New headunit in a mk2 help
Hey there,
I hate to start a topic that has been asked so many times before but anyway
I started wiring up my new headunit and I've connected brown to black (earth) and red to yellow (constant 12v) and I learned that blue and grey does nothing but all that's working is the cd ejection, nothing else is switching on even with the engine on!
DF430F9C-03D8-4A4A-B033-C25A71A7FB66_zps
(By the way that joining of wires is only ten part while I sort this out)
What do I do now? Is there a way of making it work without an ignition wire so it is just always on? What is the easiest way of getting/making an ignition wire?
  • Replies 8
  • Views 601
join the ign wire to the red..it will always be on then
grey /blue is illumination
Sorry what I mean is how would I get an ign wire? As in I don't have one stock
either join both the ign and always live from the head unit to the live you already found- the unit will work all the time regardless of the key
or root about under the dash for a suitable ign live and splice into that
Oh I see, thanks very much
  • 3 months later...
So I've had the headunit wired in and working for a while now but I've decided that today I'm going to try and get an ignition wire so it turns on/off with the key.
I just tested the cigarette lighter but unfortunately that's a constant 12v. Does anyone one know an easily accessible ignition wire that I can splice into? Thanks
The supply (Black/Yellow ? wire) to the heater fan switch should be an ignition ON supply :)
Thanks, do you know where abouts in the dash that would be located?
Never mind I found it, thanks a lot
